How to Block Threads & Forums
Discussion in 'DRC Forum Usage & Info' started by dlynx, Oct 29, 2008.
Thread Status:
Not open for further replies.
  1. dlynx
    dlynx New Member
    You will now be able to ignore users, threads that you choose, forums that you choose, and when/if we begin to use them, certain thread tags.
    In order to block a forum, enter that forum you want to block (e.g. Political Mumbo Jumbo) then use the "Forum Tools" drop down menu to select the ignore forum option.
    To block a specific thread, enter the thread you do not want to see, and use the "Thread tools" drop down menu to select the ignore thread option.
    From the User CP you can see what forums/threads you have ignored and remove any that you no longer want to be blocked.
    Additionally from the User CP there is some advanced ignore settings that you may want to use that will hide the forums/threads that you have selected.
    Thanks for the suggestion,
    Dan
Thread Status:
