Under sustained load, the stock fan can only cool this CPU to 60C. I'm not happy with that.
What thermal grease did you use?? I use Arctic silver and generally stay in the 40's.
I used the paste it came with. It was pre-applied.
Yeah, I should have done that in the first place. Last night I got it up to 75C. The fan responds, but that's scary hot.
I installed the big honking heat sink and fan. What a pain in the ass. I should have done it when I built the beast. But it dropped my temps @ sustained 100% load by 20C.
I've got it at 3.52Ghz now, and I definitely see a change in the temps. More ticks means more heat; there's no way around that. I think my front fan is too slow now. Maybe I need a new case...
This is my work PC. HP 7100 Elite with a Core i7.
