My Xmp3i Radio Turns Iself On Without Me Doing Anything
Discussion in 'XM Portables' started by hwkn, Jul 9, 2015.
  1. hwkn
    hwkn Active Member
    I'll turn the radio off after taking the battery out after recharging it and not long after that it'll turn back on(i'll turn it back off but not long after it'll be on again).It's been doing this off and on for the last few weeks.
  2. HecticArt
    My old Stiletto 2 used to do that, but I'm not so used to hearing about the XM radios doing it as much.
    Have you done a reset and erase?
    Factory reset?
    Firmware upgrade?
    Is the battery life still doing OK?
  3. hwkn
    hwkn Active Member
    The battery life is about 2 hours or so on a charge.[i'm doing a restore and erase right now]....it's on the latest firmware I do believe[bought it reconditioned a few months ago]
  4. HecticArt
    2 hours sounds like a battery drain issue. I've heard that a bad battery can make them reboot, but I'm not sure if it could cause them to wake up on their own.
  5. hwkn
    hwkn Active Member
    The thing is after I recharge the battery I remove it so it doesn't overcharge......it's plugged in when it turns itself on.
  6. HecticArt
    Curious. If your reset doesn't work, see if you can reinstall the firmware. (I've never done it, so I don't know how to go about that.) If that still doesn't work, you might give TSS a call. They know a lot about troubleshooting these things.
  7. hwkn
    hwkn Active Member
    It's off right now after the reset so for right now it's fine.
    HecticArt likes this.
