Outdoor Antennas
geosync
1,907
326
88
Portland, Or
So I'm still having trouble getting any terrestrial signal here where I live. I get it a block away, it's wacked out. Was looking at the outdoor setups. Hard to tell from the description but as I see it I mount it, run the coaxial to one of my decks. Now does anybody know if it boosts the signal only to that dock or around my house. I have three docks in the house. Thanks.
12,117
Which one are you using?
The outdoor antenna will work for the dock that you connect it to. It doesn't boost for the area around it.
