SiriusStreamer is now SiriusXMStreamer - supporting both Sirius and XM Radio!
Discussion in 'SIR & XMRO Internet Radio' started by TheEndless, Dec 22, 2009.
  1. cammy85
    cammy85 New Member
    While it has its problems as you said, it does work properly with XM Canada and SiriusXM. I was able to get Howard Stern's show for a bit. I can't wait for the final!! Thanks for the heads-up and link!!
  2. NemoPoker
    NemoPoker New Member
    plays for about a minute then suddenly stops :(
  3. NemoPoker
    using the new beta it works for about a minute then stops
  4. SirJMark
    SirJMark New Member
    Plays for about a minute here in the US, then quits.
  5. tom.amitai
    tom.amitai New Member
    Starting yesterday, 2012-08-30, and continuing today, SiriusXMStreamer 1.9.11.0 is playing for only a few minutes at a time, then it stops and gives the error message "Exception from HRESULT: 0xC00D11D2". It doesn't do it on all channels, though. I tried channel 6 and it was ok for the 20 minutes I listened, but both 101 and 104 were crapping out after a few minutes. When 101 cut out, it didn't show the error, and the timer kept running as if it was still playing, but there was no audio.
  6. cammy85
    cammy85 New Member
    I noticed in Canada that Sirius Canada now redirects to SiriusXM Canada - SiriusXM Canada which doesn't work well with the streamer. :( Hopefully version 2 final should fix this.
  7. rmf136
    rmf136 New Member
    Same here. The problem is with the audio stream coming from Sirius and not specific to SiriusXMStreamer. For example, if you copy the URL for the "Direct Stream" of any particular channel and open it in WMP, it plays for a few mins and then drops. The "Direct Stream" is the actual stream reflector (with the embedded URL token/authentication) created by the server @ SiriusXM.
  8. tom.amitai
    permanence.com seems to be down. Anybody else having trouble accessing it?
  9. Goodeye
    Goodeye Member
    Looks down to me. I'm getting a custom coming soon page, what site is it exactly?
  10. rmf136
    rmf136 New Member
    The page loads fine for me: "http://www.permanence.com/sirius/". For what it's worth, I cleared the wmp library cache and siriusxmstreamer has been running uninterrupted for the past 2 hours. Also, make sure the proxy settings are configured correctly.
  11. tom.amitai
    What proxy settings?
  12. enfuego360
    enfuego360 New Member
    So, any solutions to the drop outs? Both SiriusXMStreamer and XMTuner are having the same problem. Is this SiriusXM playing with the streams again? Are either of these programs being supported any more?
  13. cammy85
    cammy85 New Member
    Looks like the programs are useless now. :( Sirius Canada now redirects to siriusXM and wants a captcha code. :(
  14. varunaX
    varunaX New Member
    okay, so i am not the only one to have all these streamers crap out all of a sudden?.
    Usirius is 'unable to login' , my sirius yahoo widget wont login, siriusxmstreamer is 'unable to identfy captcha'...
    anyone know why they all stopped working all of a sudden? i cant force myself to believe these programs are useless, I use them every single day. this really sucks....
  15. tom.amitai
    100, 101, and 104 streams working properly today, so far. Let's hope that whatever was wrong has been fixed.
  16. varunaX
    varunaX New Member
    What program are you using and how did you even login? I'm getting an error upon login that I've never got before
  17. rck888
    rck888 New Member
    I've had the same error message for weeks now, it was working fine up until this point. I think SiriusXM is cutting the stream for 3rd party streamers b/c it ties up the bandwidth.
  18. tom.amitai
    If you are referring to me , I am using SiriusXMStreamer 1.9.11.0. That is the subject of this thread.
  19. tom.amitai
    Unfortunately, it stopped working again sometime between 6pm yesterday and 2:50pm today, eastern time. I am getting the red "exception from hresult 0xC00D11D2" error.
  20. varunaX
    varunaX New Member
    How are you able to login though? Like rck says, logins are no longer working for anyone now that they changed something...
