starmate home kit compatible with stiletto 2?
Discussion in 'Sirius Portables' started by nsshue, Feb 28, 2010.
  1. nsshue
    nsshue New Member
    we already have a starmate home kit...any problems using it with stiletto 2?
    connections seem to fit, but hesitate using it until we know it would be ok.
    Aaron likes this.
  2. What starmate is it? If it is the ST3 or higher than it technically will work. I would just worry about someone bumping into it and snapping the docking port on the SL2. I would really suggest getting the sl2 home cradle if you have a st3 or higher. This will get you the right dock and use the power cord and antenna you already have. Here is a link to the dock: Stiletto 2 Home Cradle
  3. nsshue
    nsshue New Member
    thanks
    I went ahead and got the Stiletto 2 home cradle...thanks for the link :)
  4. Not a problem. Glad I could help.
