I picked up one of these XMBB1 Boomboxes tonight at BB. Since I am down to just XM I needed an XM boombox. This one works with the Skyfi3, Inno/Helix, XMp3, Xpress, RoadyXT.
The sound is really good, I am very pleased with it. It does not come with a remote, but the remotes that you have for you XM Radio will work. It comes with a home antenna. You can use 8-C batteries to take it with you without AC power. I really like the nice carrying handle, which makes it very easy to move around. It also includes an aux-input and headphone out jack on the left side as you can see by the pictures below.
Yes I know I need to dust! LOL
Here are the exact specs on it:
With the XM Sound System from Audiovox enjoy XM Music, Sports, News, Talk & Entertainment in the home, in the office, or during those occasions when you want to take your XM experience with you.
Features:
Features:
- Two 3.25” low-frequency woofers, two ½” high-frequency tweeters, bass boost, and a 10 watts RMS amplifier produce quality sound
- Audio In jack for playing an iPod/MP3 or CD player
- The neutral black plastic and matching cloth grille design allow the system to fit with almost any decor
- Foldable handle, internally stored XM antenna, and over 18 hours of battery life (8 C cell batteries) for taking the system from the home or office to the patio, picnic, lake house, etc.
- Headphone jack, conveniently located on the side of the system, allows for private listening
- LED indicator for power, volume will show on the Radio itself
- Audiovox Xpress
- Audiovox XpressEZ
- Audiovox XpressR
- Delphi XpressRC
- Delphi RoadyXT
- Delphi SKYFi3
- Samsung Helix
- Pioneer Inno
- Pioneer XMP3
- Dimensions:
XM Sound System: 405mm W x 147mm H x 184mm D
Adapter: 49mm W x 78mm H x 35mm D - Weight:
XM Sound System: 7.4 lbs / 3.345 Kg
Adapter: 0.31 lbs / 0.142 Kg - Inputs and Outputs:
XM Home Antenna Input: 1SMB connector
AUX In Input: 3.5 mm diameter mini stereo jack
Headphone Output: 3.5 mm diameter mini stereo jack - Power:
DC: Normal 12V (6-16V), positive polarity, (+ inner conductor)
Battery: 8 C cell alkaline or rechargeable - Temperature:
Operating: -25°C ~ 70°C
Storage: -40°C ~ 70°C - Audio Power: Maximum 5W RMS per channel at 1% THD at DC12V power supply (power output is reduced when the power supply is less than 12V)
- Frequency Response: 100Hz ~ 20KHz @ +/- 3dB
