XMp3 Battery problem.
Discussion in 'XM Portables' started by v1ru5, Nov 3, 2009.
  1. v1ru5
    v1ru5 Well-Known Member
    From a fully charged battery my radio will play for 45 minutes then the battery will completely die. Is it the battery or something wrong with the radio. Radio/battery is 5 months old.
  2. hyson
    hyson Forum Jerk
    Sounds like a battery issue. Mine lasts forever.
  3. shabadoo25
    shabadoo25 New Member
    You might have to swap it out with Pioneer. Either that or TSS might have some. I've seen them on eBay for about $15.
  4. v1ru5
    Thanks fellas, glad it's not a problem with the radio.
  5. TSS Taylor
    TSS Taylor DRC Fan
    That's a good deal if you need one $15 for an XMP3 battery.
  6. v1ru5
    I'm gonna have to, the battery is only under warranty for 90 days.
  7. robhurlburt
    robhurlburt Well-Known Member
    def sounds like the battery. I have used mine for 2 hours at the gym and had plenty of battery left
  8. v1ru5
    Update.
    I tried an experiment. I played my mp3/wma's and the battery drained normally. So it's only when I'm playing live XM that the battery doesn't drain properly.
  9. Mikey394
    Mikey394 Member
    no battery problem here. two batteries and 4 AA's I get about 12 hours of Satellite time.
    [​IMG]
  10. v1ru5
    Where did you get that?
  11. DAB
    DAB Mod Emeritus
    Wow... SWEET! I've seen those for iPod's too, but wondered how well they worked.
    12 hours of sat time is very nice indeed!
  12. v1ru5
    Where can I get one of those?
  13. Mikey394
    Mikey394 Member
  14. v1ru5
    I have a 5v 3amp battery. If I use that will the amperage fry my radio?
  15. v1ru5
    Any one?
  16. hwkn
    hwkn Active Member
    My XMP3i only holds a charge for about 90 minutes before it has to be recharged.(It' s a refurbished radio I bought from TSS a few months ago it's been that way since I bought it.....started at about 2 hours a charge)
  17. hwkn
    hwkn Active Member
    Would a new battery help with the problem I mentioned above?
  18. hyson
    hyson Forum Jerk
  19. hwkn
    hwkn Active Member
    I think the problem is the battery in the XMP3i gets overcharged and stops holding the charge for as long as it should[i've read elsewhere about people with the same problem with their XMP3i's].That too seems to be my problem.[I never had this problem with my Delphi MYFI radios]
  20. HecticArt
    Unfortunately rechargeables have a life expectancy.
