XMP3 info extras not working
Discussion in 'XM Portables' started by dart74, Jul 9, 2010.
  1. dart74
    dart74 New Member
    hi, i just got an XMP3 a few days ago, the extra info stuff worked for a day and now its not. under the settings i can only select stocks when before it had sports to. anyone else have this problem.
  2. IdRatherBeSkiing
    My old Airware and the Tao have a mode where they would display nothing, stocks, or sports. I think the XMP3 may have a simular setting. If you are stocks you may have hit that button to switch.
  3. dart74
    dart74 New Member
    the only option i have is stocks, sports is not there.
  4. semipenguin
    semipenguin Bum Looker
    Have you added the teams you want the extra info for? :scratch:
    Menu > Settings > Info Extras > Sprots
    Then add your favorite teams :)
    To make sure you alerts are on...
    Menu >Settings > Edit Alerts > All Alerts: On
    I hope that helps. ¡Viva España! :party:
    Posted via Mobile Device
  5. dart74
    dart74 New Member
    like i said it worked for a day, but now it does not give me the option to select sports. only stocks. all alerts are on. on the main screen, bottom it says to add sports go to Menu > Settings > Info Extras > Sports
    but it just has stocks.
  6. semipenguin
    Try pulling your battery :)
  7. dart74
    dart74 New Member
    i have done that a few times, i also did a restore. its only a few days old so i think i will see if i can get a replacement.
  8. HecticArt
    Sounds like it's time unfortunately. Good luck!
  9. dart74
    dart74 New Member
    ok i got a new radio from best buy, with still the same problem. is sports extras even working. cause it worked for a day, then for two days it was saying no info available . i turn off sports extra. since then its not even an option to select. on both old and new radio.
  10. semipenguin
    I dunno :idunno:
    I can try mine. I never use it to check scores. Only for game alerts :)
  11. dart74
    dart74 New Member
    i just want it for game alerts also.
  12. IdRatherBeSkiing
    My Tao has always on occassion said 'no info available'. But it comes back in a little while. I don't have an XMP3 but it seems odd that it would be a defective unit given it has happened on 2 different units. Are you getting terrestrial coverage or sat signal? Is it docked? These may play a factor or there could be a setting somewhere on the XMP3 which turns it on or off.
  13. semipenguin
    Yeah, I can't help you. I can't get mine to turn on either. I don't use it anyway :shock:
  14. dart74
    dart74 New Member
    ok so im not the only one then, its on sat in the home dock. i wonder if the system is down or something. oh well thx for the help.
  15. semipenguin
    You're welcome :hatsoff:
  16. IdRatherBeSkiing
    It goes down every now and again. And it is currently down on my Tao. So that would explain it. You could call XM.
  17. dart74
    dart74 New Member
    looks it its back up, working now
  18. hyson
    hyson Forum Jerk
    The XMp3 has a sports options? WTF?
    Sunovabeech!!
    I'm gonna have to mess around with mine when I get home.
  19. IdRatherBeSkiing
    Most XM radios do. Even my old RoadyXT had it.
  20. hyson
    hyson Forum Jerk
    I'm not as experienced with XM units as I am with Sirius ones. I never really even touch Cpt. BMF's old unit :)hhh:) so I'm not familiar with all of the features. I actually just usually stays parked at 202.
