XMP3s and Scheduled Recordings
Discussion in 'XM Portables' started by shabadoo25, Jun 29, 2010.
  1. shabadoo25
    shabadoo25 New Member
    Can someone with the original model running 1.30 software explain to me how you get shows to record consistently? I have 2 of them programmed in right now and never get either of them.
    Tricks? Tips?
  2. Mikey394
    Mikey394 Member
    To schedule a recording session for the future:
    1 Select rec → Schedule Recording or Menu → Live XM → Schedule
    Recording.
    2 Use the wheel and XM button to enter the date, start time, end time, and
    channel.
    3 Select OK when done.
    You can use the same method to edit or delete an existing recording session. You can also use the
    XM2go Music Manager to create, edit, and delete recording sessions.
    Your XMp3 radio can record up to 5 separate channels at the same time.
  3. shabadoo25
    Thanks. However, I wasn't looking for a regurg of the operating manual.
    I know HOW to schedule recordings. I don't know how to get the unit to actually record them!
  4. Mikey394
    Mikey394 Member
    If you have a good signal, the above should let it record, if not you need a new unit:( or try a erase and restore.....
