This is my battery usage
I've tried to delete apps that use power & data when I'm not using them
Oops. I did date usage.
Here's battery usag
Then look to see what is using most of the power. Then fix or disable whatever that is.
Weird. Mine is great. I never touch the cache. Battery life took a hit right after Lollipop installed, but I let it drain a couple of times and accepted some app updates and everything is good again. Maybe it's because I use the Google Now launcher?
You never told us which apps are draining the battery. Is it all porn?
Maybe uninstall Life360? What's it for?Well, now isn't that special. It's special. Let me have a little Meme happy dance.
No porn.
But sometimes this comes up ...
When I go to the app setting, I see this ...
Don't know what to do to fix it. I just clear the data & move on
Tell her you need to uninstall it for a few days to see if it's farking up your shiz.
Text her pictures of road signs a few times a day while you're checking to see if it's that app or not.
Have you done the factory reset of the phone? (I haven't re-read the thread. Sorry if you already told us.)
