Gloves would have hurt less…..Yet you somehow managed to not use this to your advantage in a life of untraceable crime and instead settled on architecture.
You had to bring this up. I got stuck having to drop her off here, just an hour ago.
Same for me, every 2 months. Tali gets groomed every 6 weeks. It was $185 with tip, but it includes a bath, full cut, nails clipped, and ears/eyes cleaned. That's what we get for having a "non-shedding" dog. Our other dog gets a bath and nails clipped like twice a year.I get a haircut around every 3 months and it costs $35 including the tip.
All I need is a 98" TV.Beautiful house, dude
Correct. The first thing they do is read the diagnostic code. Most of the time, it will indicate the specific problem. Although there are cases where it reports a symptom but not a single cause.I always assumed the modern cars had almost everything computer controlled.
Software doesn't make a car move. You need electrical/mechanical things to work. This is true for any car, even a new electric one.I would assume that anything like a misfiring cylinder would be a software issue.
Good luck Scotch. Wishing you get back on the road soonCorrect. The first thing they do is read the diagnostic code. Most of the time, it will indicate the specific problem. Although there are cases where it reports a symptom but not a single cause.
I always assumed the modern cars had almost everything computer controlled. I would assume that anything like a misfiring cylinder would be a software issue. But I don't recall how old your car is.
This is what A.I. has to say about it:So the high-voltage is generated right at the plug, which is more efficient. But now you have (in my case) 6 little coils that are generating high charges, many times a second. So eventually, they arc or short out. And then you get no spark for that cylinder.
The diagnosis confirmed this, for cylinder #5. But of course, there's more. The spark plugs - all 6 - are pretty fouled, and should be replaced. This is not a big surprise, as the car has almost 90k miles, and the plugs would need replacing at 100k anyway. What is surprising is what the parts + labor cost for that is. But again, it'll be once in the lifetime of the car.it felt like a familiar ailment, where one of the cylinders isn't firing because the ignition coil has fried.
Yep, you go in for the $40 oil change and leave hundreds or thousands poorer.The diagnosis confirmed this, for cylinder #5. But of course, there's more. The spark plugs - all 6 - are pretty fouled, and should be replaced. This is not a big surprise, as the car has almost 90k miles, and the plugs would need replacing at 100k anyway. What is surprising is what the parts + labor cost for that is. But again, it'll be once in the lifetime of the car.
However, the estimate was pretty shocking. That's because they add-in all the "recommended" stuff; in my case 4 new tires and a 4-wheel alignment. They said the tires are getting kind-of low, but are not that bad yet. However, they figure I'd want to just go ahead and do it now, so they throw that hefty cost into the estimate. I do not want new tires yet. I want a year to recover.
The worst example of this was last spring, where I had prepaid for like 3 years of oil changes (the previous winter). So I thought I'd get my free oil change, free car wash, and drive it home. I needed a set of brakes (pads, rotors, and calipers, maybe $850), a cabin air filter ($100), a radiator flush ($150), and... oh, we found where that oil leak is coming from. New oil filter housing, $900. So a free oil change was $2k.Yep, you go in for the $40 oil change and leave hundreds or thousands poorer.
I can relate. Just dumped $990 into my son's 2005 Corolla today.What is surprising is what the parts + labor cost for that is.
