Today I'm going to change it up, and post about 2 products I like!
Like: I know it seems odd to be so enthusiastic about a beard trimmer, but this Philips-Norelco Wet & Dry trimmer is like the Cadillac of trimmers.
It's as solid as a tank, and fits nicely in the hand. And it's crazy quiet; just a hushed hum. It came with many more attachments than shown here, but I mostly use the one with the rotary adjustment knob. It easily provides a precision, uniform, painless trim. Plus, I got it for Father's Day, charged it once, and it's still running on the same charge! I believe this is the 7000 model, which is $65. It replaces the annoyingly buzzy, flimsy, poorly working Wahl that I had.
Like: This Outdoor Master Shark 3 pump for inflatable kayaks and paddleboards is in a class of its own.
There's a backstory to this. Many years ago, Mrs. Scotch and I had a pair of rigid kayaks, and a Toyota Tacoma pickup to haul them around in. When she changed to a wagon/SUV, we tried using a roof-mount double kayak holder, and it was way too hard for us aging folks to hoist and secure two substantial kayaks up that high. Aside from that, she got into stand-up paddleboarding (SUP), and she found that it's much easier to secure a rigid SUP on the roof. She even bought a proper holder.
As for me, as much as I like the concept of the SUP - it looks easy to paddle and enjoyable - I do not do yoga (Mrs. Scotch does); and so it's not possible for me to get out on the water while kneeling on the board, and then stand up while moving on a river or lake. And even if I could, I wouldn't be able to remain standing if I encountered anything that might jostle the board.
So I got an inflatable kayak. But being my first one, I've learned what's good and bad about it. It's a little like a pontoon boat - the sides are kind of big and high, making paddling harder than if the sides were lower. This is a "sit-in" type, not a "sit-on" one. And then there's the inflating, deflating, carrying, rolling-up into the bag, etc. It's not light; it's like 40 lbs. (Mrs. Scotch's rigid SUP is 26). It came with a hand-pump. It only needs to go to 3 psi, but between carrying and pumping, I'm spent before I even get out on the water. I became reluctant to use it, and then the hand pump started leaking.
I then started looking at alternatives, and I found that there are inflatable, sit-on-top kayaks that are very rigid. They use "drop-stitch" construction, whatever that means. Anyway, the one I plan on getting inflates to 10 psi, making it about as rigid as a solid kayak. But I'd want to get a good electric pump. Nowadays, you can get a pump that's battery-powered, so it doesn't need the 12V outlet from a car.
And that's where the OM Shark 3 comes in. It's been out for about a year, and it's twice as fast as any other pump. It'll pump-up my future kayak in 3 minutes, where every other pump takes 7. It has 2 motors. Right now, I'm using it on my current kayak, and it pumps each side in about 30 seconds. And you can program the psi limit; when it hits it, it shuts off. So if any of you have inflatable recreational gear, get this pump.
